  • Replies 6k
Posted Images
nah sam, 1st time there if i remember correctly. something to do with the fact that since his ebc wasnt working properly the was allowed to drive off without paying a cent but will pay full amount when he get a tune with a working ebc. wierd.
nah, its still here. i cant get the work done until i can borrow my sisters car. shes on holidays atm. so once shes back at uni, i'll drop the skyline off and borrow her pulsar.
are you still in the process of gathering parts?
i drove it a few times. Gearbox is very funny in terms of shifting to say the least. But it has tidal waves of torque compared to the line. s2000 is a different story - it has an awesome gearbox. Shifting is go slick and fun in that car.
Bachelor of IT.
I'm in my 3rd year so yer exams suck. :(
Especially J2EE - Internet Computing.
I'm a fiddler. I only 'try' to improve upon the current cheap $100 tune I had.
I found that when changing gear or simply flattening it the map trace was dipping to load point 20 then once accelerating settling on load point 19 through the rev range.
This load 20 point was running ever so slightly too much timing as it was causing highish knock readings.
I reduced load point 20 by one degree and left load point 18-19 the way it was and knock went from 35 down to 17.
So.. I dialed in another degree in to load points 18-19 and found knock didn't rise.
That 1 degree makes it feel more lively, but only makes throttle control that little bit harder in second.
Basically through the mid range its now running 17degree's instead of its previous 16 and in some parts 15.
These new tyres don't hook up though. :)
I bought some Firenza ST-03's.
If I don't ease my foot in to it second axle tramps majorly. :D
My subframe bushes are screwed, first things first during the holidays, I'm going to fit some pineapples, hopefully it will stop the subframe from slopping about and help with traction a little.
If I still get too much movement, over the X-mas holidays I'm going to drop the subframe and fit a set of new subframe bushes from Noltec ($190 from Unique Autosports).
Maybe, a big MAYBE fit a S13 3.9:1 diff as to help the rb30 get that little more speed from each gear.
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
