  • Replies 6k
Posted Images
I dont listen to music on my PC when im at home cos Im usually sitting on the couch watching foxtel aswell as surfing the web..
haha, i do that too
But at work I listen to the radion while on here.
whats the radio like over there? radio is shit here, too much short attention span pop shit...
ah slim is a net surfing couch potato. im assuming its on a laptop cant imagine u on a destop sitting on couch watching tv or am i wrong? lol
LoL.. yeh its with the laptop.. although..before I had it..
I did have the PC set up on the couch when I was doing work from home lol.
Wasnt very comfy
do u listen to them while in the car as well?
if so does it get your adrenalin pumping? hehe
sure do, passengers usually dont agree. i cant listen to heavy stuff in peak traffic cos i get too pissed off at everyone...
whats the atmosphere/social life like in sydney?
ive never been there before, im thinking bout heading there at the end of the year as a detour when i go to melb for the dift nats.
it really depends on where you go. what you're into.
the city night life can be great if you are into RnB or Dance high-energy music. george st can be great for some of the pubs if you are not into clubbing.
i aint into clubbing that much anymore probabrly due to the clubs they have there which are quite boring. I like scenary's and the likes - attractions ie harbour bridge. too bad the my restuarant rules diner isnt there anymore - pink salt wasnt it? would have liked to go and eat there. Do they have a casino there in sydney? adelaide's is lame. Those are the sort of things im into. =D
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
