  • Replies 6k
Posted Images
we normally sit in the stands on the front straight - there is normally an Extreme Clutch banner on the infield opposite where we sit. But we also walk around a lot and chat to guys in the pits, and all of the guys walking about - you can't walk 20 steps without bumping into someone you know :mad:
cool, im trying to figure out what to bring, last time i went we sat in front of that dogleg right before the straight, which meant we needed chairs...so at least i dont have to worry about a chair, i usually bring my digi-cam too but i forgot to bring it to adelaide :mad:
so r u coming to meet us at IF (that is the secret codename) at 10am?
yep, ill be there :mad:
Hey, how come your car has so much power with so few mods - or are only a few of your mods listed in your sig?
the previous owner had that dyno done right before i bought the car, i believe it had properly tuned power fc too, unfortionately i only got the stock computer :D . Theres another dyno that it did with 217rwkw, both dynos were done on 10psi, i got absolutley no idea how it pulled those numbers either :confused:
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
