  • Replies 6k
Posted Images
in one segment, ken nomura who drives the blitz r34 sedan decides to educate one of the public bout drifting so he decides to stand on the road and waves a compelte stanger into his workshop - stanger was driving quite fast btw in a luxo merc. He asks the guy if he knows what drifting is and he replies no so ken takes him out in his r34 and teachs him to drift. The guy cant do it for a while - lots of bloopers but eventally is able to drift but at the end manages to rip the front bar off - the crew were laughing their heads off but ken was not happy and the driver was constanly bowing in shame.
gotta watch it to find it funy, hard to explain.
note: if anyone ever needs paint for an early COB (clear over base) nissan, make sure you type CLR (into paint code database) in front of the 3 numbers that are on the ID plate.
say again brother?
say again brother?
tricky to explain, ill give an example:
paint code on the N13 pulsar is 569
type that into the computer and it will come up with a toyota & a ford formula.
try typing CLR569
and then the nissan one will come up
weird hey? only car manufacturer i know that does that. mostly on pre-90s model nissans
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
