  • Replies 6k
Posted Images
in one segment, ken nomura who drives the blitz r34 sedan decides to educate one of the public bout drifting so he decides to stand on the road and waves a compelte stanger into his workshop - stanger was driving quite fast btw in a luxo merc. He asks the guy if he knows what drifting is and he replies no so ken takes him out in his r34 and teachs him to drift. The guy cant do it for a while - lots of bloopers but eventally is able to drift but at the end manages to rip the front bar off - the crew were laughing their heads off but ken was not happy and the driver was constanly bowing in shame.
gotta watch it to find it funy, hard to explain.
note: if anyone ever needs paint for an early COB (clear over base) nissan, make sure you type CLR (into paint code database) in front of the 3 numbers that are on the ID plate.
say again brother?
say again brother?
tricky to explain, ill give an example:
paint code on the N13 pulsar is 569
type that into the computer and it will come up with a toyota & a ford formula.
try typing CLR569
and then the nissan one will come up
weird hey? only car manufacturer i know that does that. mostly on pre-90s model nissans
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
