yep, the Island is a great movie - really makes you think (similar idea to the Matrix). And I could sit and gawk at Scarlett Johansson for hours on end - you could mute the sound and I'd still sit there and watch her for hours and hours .... same with Angelina Jolie in Mr. & Mrs. Smith ;)
I thought Sin City sucked ass - very hard work to watch. I have no conception of the comic book series, so had no idea what to expect. The characters and effects are very cool, but the way the movie is directed in comic book style really pissed me off.
  • Replies 6k
Posted Images
@miss_petepie, being catholic myself i do. Dont know bout the other sa members though.
@slim, its a shame we dont have track days here. Wished i lived in Vic/NSW at times.
Edited by Nozila
we have a weekend at this track in collie soon
we stay over night and have a weekend of drift on track
and recently they changed the track and added a tunnel and poo..
sooo excited.. cant wait to get out on there :P
here here Slide and somedays when racing on Sundays, Saturdays are also track days. mmmmmmmmmmmm Track Days
AMEN the only religion in is the CAR GODS and even then they are still bitches :lol:
since u guys are ment to be the city of churches...
do many ppl actually go to church?
I live acroos the road from a church.
On Mondays it has AA meetings.
Tuesday it has some kind of class for oldies.
Wednesday is drama school for the young'uns.
Thursday is Postwhores Anonymous.
Friday is a day of rest, followed by all the sins that evening.
Saturday night it actually gets used as a church! And the bloody churchies block my driveway.
Sunday, as previously mentioned, is devoted to the Car Gods and track days.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
