  • Replies 6k
Posted Images
Stuff having a soft top, only takes 1 sharp object from someone to cut and you have to fix($$$$$$$$)
i try not to think that anyone who looks at my car - or any other car for that fact, is a thief or potential thief.
a good british roadster is what should be bought if thinking softtop ;D
i have to admit, going for a hammer in michael capella's mx5 was so much fun to windy point
on a side note (which is what wasteland is all abotu lol) UPGARDE TIME IN LESS THAN A WEEK, YAY!
yeah thats such a negative shitty way to think, and you'll become so badly paranoid you wont even wanna drive your car anywhere anymore, wtf is the point of having a skyline if its gonna sit in your garage all the time where nobody can see it :D
ok maybe that was written out wrong. i was trying to say nobody thinks that someone is going to target their car just b/c they have a soft top - if that made sense. unfortunately, my car is in the garage where nobody can see it - not intentionally either.
it's good to be paranoid about your car to some extent. If every single person put a good alarm with immobilisation points in their car it would cripple the stolen car racket and reduce everyones insurance premiums. This would of course be a very good thing.
Especially since you have a vehicle pager system Sam and Duc - it's the only way to go imho. I am putting the same alarm as you guys in my R34 before I put it on the road. It should be the law imho.
the pager system makes leaving your car parked anywhere a bit less nerve-racking. so when is the 34 all ready to go? :D
