  • Replies 6k
Posted Images
id be more than happy to do that. with the previous cruise, thats why i did - went crusing in the hills in the missus celica and worked out what roads were nice and so worth. end result was what we eventually cruised on which everyone seemed to like.
Yeh that was my car, but not too sure if it was me sitting behind the table, Tall with blonde hair?
cant remember, its been some time now but im sure the stand was promoting the products you had in your sig.
rofl @ the looking so sad comment. mines in the shed with a faulty starter motor i suspect. so im going to sort that out before i drive it again plus it ran out of rego the saturday that went by which co-incidently was also when the car started to play up (bad luck and timing i guess).
No i don't have any thing in there yet, prob only go for the Cradle bushes, As i already have Cusco Strut bracing, I might go a Steering bush.
Christian Pickering has had the strut bracing in at the G1 event and claimed it was stiffer than Viagera, and Kelly McKinnon and James Mardle runs his stuff also. The product is made from Aircraft Billet Alluminum and is strong as, and is HEAPS light, can't believe how light some of that stuff is. Did you check it out at Mallala?
upgrade to what chillam? im assuming your talking bout cars btw
no, loyal to the origens of twin cam RB... the 20!
But, goodies included in upgarde:
RB25 series 1 turbo
SAFC2
Remove inlet butterflies on inlet plenum
Fix busted studs on exhuast manifold
Rebuild clutch cylinder
Full Serive and Dyno tune
I cant wait to see the dyno sheet!
I go out for the night and there are hundreds of pages to read!!! you guys are hilarious.
RB25 series 1 turbo
SAFC2
remeber to post the result here with dyno sheet ;)
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
