  • Replies 6k
Posted Images
not bad. spent friday and this morning painting, thats about it. took the sil80 for a drive after the panels were painted and also lose it around a corner - having said that, i did take it at 5000rpm in 2nd gear. was showing how the car handled to a wrx driver who lived in the area. hehehe
yourself? how was your weekend and what have you good planned, if any, for tomorrow?
hehe, did you know the WRX driver? hope you didnt lose it too bad? im probably not doing much tomorrow, probably sleep in.. ususally id go driving, i could go for a bit of a drive, if i dont stop... but i cant afford petrol either :lol: oh well
yeah wrx drivers was my brothers friends older brother - if that made sense. he shitted his jax and do did i, wasnt expecting it to do what it did. yes, petrol is insanly expensive atm. ~$1.25 ish for unleaded. now its becoming a joke.
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
