  • Replies 6k
Posted Images
rofl ... j/k whiteR33 .... I love Tasmanians - nearly as much as Tasmanian blokes love their sisters :D
haha true Jar - actually I'll check for you - I am in Tijuana on Tues 20 September :D
Dont bag my sister until youve had a ride :lol:
