yes i think i would be. saw a few 'wildly' modifed scooters while i was at gt autosound a while back. i think one had a nitro system installed on it and upgraded brakes ON A SCOOTER bbaahah :D now that would defeat the purpose of a cheap run around, fun yes, but thats not the point. :P
  • Replies 6k
Posted Images
scooter cruise!!!! my gf is 'apprently' related to the owners of The Zone on rundle st who also has scooters for hire. maybe we should organise a group hire, hahaha. but then again, we can just drive our cars. i cant see us all scooting up to victor/the hills with them but a town cruise would be hilarious.
true to that, no crashing on the scooters......So Duc what did you do with yourself on the weekend?
did some welding saturday morning. my safety protection wasnt that great, i didnt feel anything until later that evening. ended up with not being able to see half way through the night (at the time has just finished dinner at villanova and was gonna go play some pool across the road when i just started crying) therefore missus insisted to take me home. :D spent most of the sunday with an ice pack on my eyes and wearing sunnies for the rest of the time. oh was also told that evening that the crows lost to west coast eagles DOH!!! i had bets on the crows too. What did you do with yourself on the weekend?
Hello MsSkyline i see you here all the time but you no say nothing.....Thought i would just say hello!!
maybe she is one of the female drivers you frequently refer to spotting on the road. MsSkyline, are you skimming the wasteland on a mission?? :D
So you started crying......I think this was all planned by yourself, I bet you spent all day Sunday with the ice pack on your croutch and the sunnies were from a late night. am i close......
What were you welding? and wheres your Safety goggles not beer goggles?
I went to the drift on Sat night, then went 4WDing with a mate at lonsdale until 4am, and then Sunday went and watched the Sprint Karting out at Bolivar.
creative asumption there Darren but thats far from the truth
was welding leak in exhaust, gasket didnt do much. yes used the welding mask but occasionally rather then all the time.
if my eyes didnt decide to make a water feature of itself i might have been able to go and SEE it
there are many ideas going through my head as to what you mean, since you have a dirty mind  :lol: please elaborate.
Dirty mind.......no not me :D
Do i really need to elaborate? She can Dinky me anyday, but i will be facing the wrong way......
Shit that almost rymed, hidden talent i think not!
i wouldnt have though you would elaborate :lol: imagine what you would do when asked in a non sober state
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
