  • Replies 6k
Posted Images
wheni bought my car i just had a quick once ovevr myself, and then got my dad, who was a mechanic 2 have a look...seemed find, ran fine...usually with these sorta cars u can tell if somthings really fked...but like all cars, if its gona break, its gona break hahaha...afta i got mine, cat went, clutch went, radiator went, water pump went lol...
yeh sazilla, loosing power...very wierd...like sinastagtst, prob need new turbs...
nah steve, made no changed since 197...started feeling slugish 4 months afta tune...then had dyno day and was wtf? then when took it bk a month later was down to 160!
gona take it in next month do some runs without the exuast and check intercooler piping see if that fixes it, otherwise new turbo....and if i had $ id get a hiflow but look slike ill b getting a stockie! haha
ps, it was runing 12psi, but on last dyno, when we put it up to 11 or 12, it still gave similar kw reading to 10psi, so somthings fked there...
Edited by vange
    • Did you pay with a credit card? I'd be putting a charge back through then finding a new sparky to sort it out.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
