  • Replies 6k
Posted Images
LOL !!
I heard Greenline were better, cheaper shipping etc. hahah, anyways got the kneecap in a jar at home, so I can unzip the leg and whack it back in (like false teeth) as I see fit... NOT.
Yeah, a tad sore now. Pill'd up but rather not take those mindbending painkillers (certainly not at work anyways). Meh. And I was going so well with the physio as well, had increased the strength of the muscles around the right knee area by over 40%.
Simply lifted left leg up and lunged to stop a ball that was kicked to me, and the weight transfer and angle on the bad leg just caused it to horribly collapse in on top of itself. Meh, I'll get used to it. Apparently its partnparcel of not having the kneecap.
LOL !!
Dude.... I got coolant poisoning from some Castrol Radi-cool at the moment and the part about no kneecap and the thought of the pain you have to go through really is making me consider inducing vomiting cause I feel like ultra-shit now. I woke up last night at 4am to find my mouth completely numb then when I read the bottle it said I shouldnt drink it? WTF? lol...
lmao.. sorry I had to laugh.
I've had coolant in my mouth before and the taste is unbelievably horrible. Nothing I did got rid of the taste that hung around all day. :D
How you ended up drinking coolant.. lol do tell us. :(
I can't remember the last time I owned a brush/comb!
:P:nuke:
my leg collapsed in on itself 2 days ago.
so sad
so PAINFUL gggrrrrrrr
tibia went out and femur came in (no kneecap), fullon collpsed into itself
ouchies
:O
:D FAR OUT!!!!
Sounds horrible hope myou are ok and get better soon
By the way I have arrived in Adelaide today :(
:P:nuke:
:D FAR OUT!!!!
cheers man, hope you enjoy wetnwindy lil'ol Adelaide, today is normal - it always rains here
I haven't brushed my hair for a good..... 8yrs I'd say.
Shaved head. :(
Shaved head is cool
I know all about Adelaide use to live here that why I moved to sydney lol
Jess
I've had coolant in my mouth before and the taste is unbelievably horrible. Nothing I did got rid of the taste that hung around all day. :nuke:
Long story short, water cooled pc, curiosity, fumes in my room, numb mouth at 4am in the morning, thought I was gonna die. (I had to syphon the shit out of my tubes).
Edited by Pauly33GTS-t
welcome Jess
sorry to hear about your knee Brendan ... were u on pain killers when u put all the thermal paste on the CPU :D
Yeh always puts on a great show for visitors!
YAY!!!
The regulars are here :nuke:
Yeah im used to crappy weather especially when we come to visit :( but will still have fun :P
Hopefully I can wish the rain away :sorcerer:
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
