  • Replies 6k
Posted Images
yeah agreed thats mickey mouse
found this while looking for a 200b or bluebird sleeper, red rims goto go but look @ all the goodies in it and its the attessa bluebird very rare
http://cgi.ebay.com.au/Nissan-Bluebird-AWD...1QQcmdZViewItem
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
