  • Replies 6k
Posted Images
i thought that the 240 above actually had a tt 4.5 in it with the most impresive pipe fabrication
ive seen the one with the tt 4.5, not sure if it that one though, thats the american one if im not mistaken, the tt is in japan afaik.
on the way into work about 30 minutes ago, was going past barry's i think it is (cant remember the name of the road there), and i see a cloud of smoke up ahead, so i wonder if its a fire or if someones doin a skid or what, a few seconds later, i see the source of the smoke;
a fairly new pulsar belching smoke out the back end, trail was mebbe a hundred metres long before it started disapating, and about 20 metres from the back of the car you couldnt see a friggen thing it was that thick. sucks to be him.
Funny because :
1. Commodore vs import.
Sad because :
1. Its a supra.
Kool because :
1. You can see [ DRTY 2 ] at the end lol (lookalike.)
was the commodore on a 60km/h cruise control? sure it was dragging? was there a launch?
thats a shame Vlad, sorry too hear :P
>_<
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
