  • Replies 6k
Posted Images
ahhh hotwire, me and my bf figured it out, just takes patience and gotta use 2 hands, one on button and one on touchpad. Best we could get was was 40 metres tho, and we were fighting over who would play lol, very addictive. Nice one!
yeah i haven't been to a dentist since i was 14yo, i had to have
(apparently) $10k work done on my teeth.
37yrs :thumbsup: that's ages.
how do you know you've never had any cavaties??
you may've gotten some in the time that you haven't been to a dentist
i haven't been to a dentist in over 7 years and i'm only 22... never had any fillings, or cavities or anything.
probably should go but the waiting list in victor harbor is like 37 years or so.
That may change if you haven't been for over 7 years. Surely there are other dentisti that you could go to than one with a 37 year waiting list.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
