  • Replies 6k
Posted Images
haha it was a slight exsagiration (go spelling!!)
well my teeth don't hurt or anything, they seem the same to me now as they did all those years ago.
Also whats up with madaz and andz? they both seem to have a lot of sand in their vagina's the past few days.
Yeah ok wot ever... i get sick of the way some peoples talk on this board and finally said something end of story nothing to see here
well you might have the tinyest(sp) hole in a tooth and not know it :P
i might be getting my tooth fixed at the Elizabeth dental thing.
which will cost me $45 i don't wanna spend, but have to if i wanna
be pain free for now.
my mum told the woman i had 4 panadine forte and 4 herron tablets
last night, they did nothing :(. the woman was worried i'd overdose
trying to kill the pain.
Edited by pokie
no not angry @ you just dont like assumptions that ive got my knickers in a knott because of 1 post that you read
and they way you portray it to be past few days
im not sure what gave you that idea hence my post wot ever.
sall good
Too true, Were all adults here aren't we??? I've been thinking of giving myself a ban from here for a while ;) too much BS starting to happen! I'd rather ban myself than have Cubes or Andrew ban me for something i really wanna say to some people....LOL
Anywho, did everyone notice that Top Gear is back on in July...... I think the 2nd of July! Should be good!
well apparently i'm getting a form from the Gawler Health Service dentis to go
to a private dentist.
i'm freakin crappin myself right now :nyaanyaa:. my mum gave me some tablets last
night that are spose to be really strong, they worked kinda, was still sore
but yeah.
haha my bro was saying last night "yeah sure hand her that, it's white why
not let her overdose" ;) ahh it was funny
well just got back from the dentist.
the guy couldn't find anything wrong, but he did say that my top
left wisdom tooth needs to come out and i need a filling (which i already knew)
anywayz he came to the conclusion that i'm grinding my teeth at night
and my gums feel pressure coz i've bruised them or something
so i have to get a mouthguard and wear that to bed every night for the
next 2wks and get sleeping tablets.
yay more money being spent :D
AHAHAH Yeh apparently i used to grid my teeth at night also, I had to have that mouth guard thingo also, and yeh that lasted a whole 2 nights and i soon got rid of that stupid thing! Also have had all 4 wisdoms out at the same time, all i can say to you on that one is Good Luck! Custard and icecream for you after having them out.....LOL
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
