Hmm nice...
Cause I have a mis fire issue at the moment in the GTR so might be upgrading the coil packs to splitfires and they are good!
Did you have a mis fire shaun? or just upgraded for the hell of it?
Phew!!!
he had a freakin crazy misfire, wasnt fun.
Yeah it does come down to price doesnt it...well I hope it all goes well :)
heh, always comes back to money.
the gtr's still on the list, but i might wait til im in another job.
  • Replies 6k
Posted Images
Aww Coil packs are a common thing to break :thumbsup: and looks like that will be my problem also...My car sounds like it has some lumpy cams, its cool but for the wrong reasons :)
Thats fair enough.... so what is this soarer..... year,colour, mods??
So we should expect you on the cruise this weekend Shaun :)
Probably not as not sure how long it will take them to do my front bar as they are quite busy at the moment.
I hope to be out though with the top secret front bar in place though.
Mine sounded like a WRX on roids. lol
It wasn't good at all, now sounds like a skyline and goes heaps harder than before.
Big thumbs up to splitfires, well worth doing even if you dont have a misfire.
silver(ish), grey leather int, comepletely standard, lol, tis just a cruiser.
but after just stepping out of a friends gtr... guh, lol, might end up not buying it, ah, decisions decisions.
Edited by scandyflick
LOL My sounds like a dragster at the moment
Where did you get your split fires from?
Glad she is all fixed up !
Oh so nice then.....I like a cruising car they are cool ;0
LOL you are making it hard for yourself but should rush into it!!
any1 here watch the Today show??
they were in Adelaide this morning hehe, i got there at like 5am
just so i could see Human Nature :thumbsup:
my friends mum was saying that they had the cameras on us alot lol
oooooooooooo i hugged Humphrey B. Bear :(
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
