  • Replies 6k
Posted Images
Sept 10th at Boostworkx
Fit cam gear (supplying group buy Aerospeed item)
Install Oil filter relocation kit (supplying Greddy item)
Oil change (z145 oil filter + Motul Turbolite 4100 oil)
Attessa Flush with genuine quality fluid
Retune inc remove and refit tailshaft (safc / sitc / 15-16psi not sure yet)
Install braided lines and bleed system (supplying Maltech lines and Castrol super response dot4 fluid)
Install Front rotors and pads (supplying Dba slotted rotors and Bendix advance pads)
got a good quote, so Im happy with that.
cant wait
looking to "feel" around 200awkw I suppose.
nice tangles. 200awkw is ballsy.
lol, cheers :laughing-smiley-014:
blue-ballsy ?
hahaahah
yeh, at the end of the day, I bought the Stagea 2 years ago with an overall budget of 30k in mind (incl 18k for car) and a setup safe for 200awkw. which is what it'll be. brakes/suspn/engine all "tuned / setup" for the HP output.
only thing missing would be the auto tranny to be serviced + shift kit; all in good time tho.
Brendan - sorry i didn't catch up with you this week i been not well since Wednesday i thought i was going to catch up with you on fri but got worse then i couldn't even talk had to get my mum to ring my boss to say i wasn't going to work ... is there an emotion for how embarrassing ;)
anyways im feeling a little better now so i imagine i will be able to catch up this coming week
well im back @ work i finish @ 3:30 Brendan i will run by the city on my way home :cheers: but where excactly will i be running when i hit north tce if i ring you are you able to meet me on the street jump in the car run around the block and drop you back :P or something like that so i dont have to get a park
