Hi Jess, nice work on the brakes :pwned:
i got mine too when i get them fitted will post some pics
Hiya Maz!!
Thanks love the suspension as well she is so low! :D
Really!! Thats excellent..what did you end up getting??
Morning SA :P
  • Replies 6k
Posted Images
Morn Jess,
i just got R33 GTSt calipers and rotors but there is a
UK dude that does 330mm upgrade packs with the R33 GTSt caliper so when i need new rotors might look into a 350z track rotor from memory they have 320mm rotors with the brembo brakes so all i would need is a bracket to remount the caliper which isnt too hard
still would one day alot further down the track like to get new rims 5stud and do the whole conversion
The only problem I can see with using brackets is if you have an accident and its discovered you could be in BIG trouble.
Insurance etc doesn't look kindly to illegal backyard style brake mods. :P
Madaz, unless your running wide super sticky tyres there's no need for 300mm+ big brakes. A decent set of slotted rotors and a good track suitable pad is perfectly fine with the std r33 gtst callipers.
Morn Jess,
Hiya!!
OMG what a day!!
Cool glad you got your brakes :sick:
I need rims also...so cant decide :P
Woo hoo! Got rained off of work today, ah it's good to be home. Gonna sit back in a few and watch The Bourne Ultimatum :pwned:
Hiya Luke..
I wish I was rained off today...dam new job and stress!!
Plus im all alone today in the office :D Thats suppose to be really good the bourne ultimatum
good Call.. will leave it as Standard 33 then, or best case find a wrecked 350z and get the brembo calipers off it with rotors
Once you figure that one out Pauly, let me know ok?
he can let us all know :wave:
I'm glad i didn't have my car on the street last night. I usually am the lst one home and have to park out the front. For some reason my dad left his car out the front. We got up this morning and someone has thrown a brick into the tailgate leaving a big mess!!
couldn't believe my luck (and my dads bad luck :rofl:)
I've always considered "rice" to be a car that's modded only for looks, and usually not particularly tastefully or over the top, like big "pram handles" on Excels, altezza lights etc.
IMO there'e nothing "rice" about a 240Z.
I totally agree there is nothing rice about any of the cars that dad owned previously, however I was pointing out that in the 70's they were referred to as "rice burners" just because of the japanese heritage.
You could hardly call 120+mph (195kph+) in the 70's "rice" by todays definition, BUT thus the adaption of the term as I was refferring to :(
Yup, that's where the term came from a LONG time ago.
Then in the 90's when everyone started putting bodykits on excels & mirages the term rice was applied to them as they were all show and no go. Thus deluxe's and others view on rice.
Then with the rise of Grey imports (silvia's, skylines etc) in the late 90's, the term rice still stuck although these cars would beat 90% of the local products of the time.
Now days, rice is very mixed, bit like special fried rice! :(
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
