  • Replies 6k
Posted Images
Well that sucked ass, just got booked going 88 in a 60 zone. Swear black and blue it was the van in front of me but the cop wouldn't have a bar of it. $300 fine and 3 demerits gone; first fine of my life. Finally taken one up the ass from Mr Popo
Not a worry Steve, as I said, first offense ever so I've still got a few points left. Just sucks that when I think about it I'm positive he had the wrong car. No point in trying to fight it though, just too much hassle... maybe I just won't pay, what did you say on the weekend? $50 for every day in jail? Hmm... a free six day holiday :)
take to court
simple
you have rights and a right to have your say in court
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
