I was pricing-up a nice r33 GTST '94 today but it looked slitly different.It had a nismo front,nice white flat-spoke rims,GTR wing,Recaros,big writing on the steering wheel and the sides of the car"Taka Kaira" .The dealer is telling me that the car is a limited edition one and all the bits are fitted at the factory.Has anyone ever heard of "Taka Kaira" R33 or otherwise limited edition R33?
https://www.sau.com.au/forums/topic/14855-r33-ltd-edition-wtf/
There was a Nissan 40th Anniversary GTS-t. With a better body kit and I think it was only released in midnight purple.
But then again, anyone could buy 25 GTS-t's and badge them in there business's name as a limited edition.
Might go again tomorrow to investigate further.On the outside the car looks shmick.However, the drivers recaro has a hole from a fag butt and the paint has come off the dash in some spots.Looks a bit grubby,however admiddedly the car is not ready for sale yet.I want to see it when they finish with it.
When I bought my car there was an NA Auto with a TommyKaira kit from the factory, with custom 19" gold wheels, rigid as heel suspension, hell it sounds pretty much identical, cept it was black, auto, and NA.
Same year '94, with silver badging on the side skirts with Tommy Kaira written on them.
Had it of driven better than a tractor, and gone faster than an excel I would have bought it. The thing was thrashed beyond belief, and the interior was about as good.
Good collectors car if you are planning on restoring it and using it from time to time, but if you want to drive it daily, make sure its worth it
[/2c rant]
Originally posted by skyline33
yeah but the 40th anniversay one comes in a few different colours (purple, black, white) and is only series II 98 models.
my friend owns a genuine 40th anniversary R33, in Midnight Purple... most immaculate Skyline ive ever seen in my life. he paid high 30's for it about 6 months ago. only had 9000kms on it, with the log books in Japanese. :eek:
someone told me its got an R34 drivetrain underneath it... anyone got any further info about them that i can pass on to him?
I have seen a few lines with the Tomma kaira kits..you can get the copy kits easy enough. Generally all white?
If it indeed is a genuine.. and midnite purple is a nice colour!
I'd snap it up even if it has some problems - they can be fixed..
Ummm a few thing might need clearing up here..
I thought all 40th Ed. GTS-t's where midnight purple ? and where series 1's ?
If it did have a R34 Drivetrain...whats the difference ? I doubt very much.
I looked at the car again today.The colour is actually dark blue.Under the bonnet the colour is matt black-coud indicate that front end was at panel beaters at some stage.No extra hardware under the bonnet as far as I could tell.But it does have an authentic looking Tommi Kaira badge on the boot.Interior looks rather unimpressive and well used, 66,000 on the odo notwithstanding.I will probably look somewhere else for my Skyline.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
