I've been doing the odd posts recently about what the 4S has/doesn't have etc, and think it's a good idea to have it in one thread.
To start -
The "25t RS FOUR S" - which we all just call the rs4s, came in as a series 2 in Aug 1998 (ie rs4s rev 1). It is a manual stagea, with the updated R34 GTT engine/trubo/intercooler that the series 2's have.
An updated one came out in June 2000 (ie rs4s rev2), hopefully we will get some details below on the diferences vetween the rev1 and rev2.
The main differences between a rs4s and the rest of the series 2 stageas are (and this list will probably grow ) -
- it is manual
- has lsd as standard (it was an option on other series 2's)
- has some R33 GTR parts instead of R33 GTT (more details coming)
- 3 center gauges (including turbo boost and front wheel power used)
- rear swaybar is larger and has a slightly different profile around the exhaust. the rear shocks are a fork type.
- HICAS (it amazes me that this isn't on the rest of the stageas!)
- R33 GTR drive shafts and diff.
- 17 inch wheels
- better seats.
I'll keep this top post up to date as people post stuff below.. :)
you can see my rs4s rev 2 at http://www.iqconsult.net/stagea/
Edited by ian
https://www.sau.com.au/forums/topic/148563-rs-four-s-stuff/
Really looking forward to seeing how this pans out...
I'm looking to move up to a RS Four S in th next few months and will be losing the line in the process. Hence I will need something that can take some moderate abuse at a circuit.
The things I'm curious about;
Front and rear driveshafts and diff (33GTR or same as normal Stagea?) Which parts are same?
Brakes (Sumitomo 4 pots like the GTT and Gtst or same as auto Stagea? And do they use the same discs?)
https://www.sau.com.au/forums/topic/148563-rs-four-s-stuff/#findComment-2780956
Easy, buy mine, it's got nearly everything you want ;)
https://www.sau.com.au/forums/topic/148563-rs-four-s-stuff/#findComment-2781456
lol, nice calls guys!
If I don't buy yours EGA41T, I'll definately be contacting you about the Secret Squirrel Tweak! In fact send me a pm about it!
by the time you buy a good one, bring it in, do a few bits and pieces, it isn't going to be too much cheaper than EGA41T's one - without the bits he has already done up. Plus you can poke and test it (as it is already here) so it is definitely worth considering.
https://www.sau.com.au/forums/topic/148563-rs-four-s-stuff/#findComment-2783389
Dose the RS Four S have the chassis stiffening that the 260RS has? Front chassis rail brace, rear sub frame bracing and upper C pillar reinforcment?
Don't know - tell me where to look, and I'll go look/take photos. Though not today (stuffed the foot so am not walking..)
Ian
https://www.sau.com.au/forums/topic/148563-rs-four-s-stuff/#findComment-2785599
went and had a bit of a look (not easy without jacking the car up...)
Stuffed if I could tell. At the rear there is bar going from side to side ie the same as 55422X, but the rest looks different.
You can have a look in FAST - my model number is TGKPREFC34UDA----- see pictures attached.
You can see at the front that it has a bar across under the engine (54611) and at the back you have the cross bar (56230) connected up to a whole solid frame, which in turn attaches (ie up from the 55080ba nut) into the side chasis rail.
Hope that helps...
Edited by ian
https://www.sau.com.au/forums/topic/148563-rs-four-s-stuff/#findComment-2788083
The 54611 bar across under the engine is just the sway bar. The 56230 bar on the rear is also just a sway bar.
The 54422X bar looks like it is unique to the 260RS and R33GTR It links the two chassis rails together about 20cm behind the front cross member mounts.
The 3 rear bits 55451N, 55452M and 55422X look like they link the front and rear mounts of the rear sub frame together.
I would love to see some pics of the bits under the rear of a 260RS to see if they will fit onto an RS4.
Nissan / Autech guys obviously thought the benefit was worth the cost for cars with stiffer suspension, more grip and more power. I think most of us are running stiffer suspension, have more grip and more power than a stock 260RS so it would probably be a worth while upgrade. I know my car has a fair bit body of flex; I can feel it and hear it creaking when turning into steep driveways or going diagonally across speed humps.
I’m thinking about buying a set of the stiffeners and getting a batch of copies made for a group buy.
https://www.sau.com.au/forums/topic/148563-rs-four-s-stuff/#findComment-2789395
Do we know if the series 2 body was stiffer than the series 1? I know for my r34 GTX that one of it's selling points was that nissan had stiffened up the body compared to the R33.
To be honest, and I agree I'm probably not hooning my stagea like a few guys here (which I did at your age in a galant - including breaking the back diff 3 times drifting >_< ), I don't notice any body flex issues in the rs4s. In fact, part of the reason my wife prefers the stagea to the R34 is that the back doesn't 'twitch around' so much..
Ian
Edited by ian
https://www.sau.com.au/forums/topic/148563-rs-four-s-stuff/#findComment-2792975
I doubt the S2 body is any stiffer. The R34 was a complete sheet metal change over the R33 so they would have taken advantage of that to make it a bit stiffer. When doing model updates car makers only make enough changes to make existing owners want to upgrade, these changes are normally visual or power upgrades. There would have been no reason to invest in tooling and engineering to improve chassis stiffness on the S2. If they felt it needed to be stiffened they would have used the braces already developed for the 260rs.
I would estimate that the chassis rail bracing would cost the equivalent of $80 per vehicle over a volume of 50,000 vehicles that’s 4.5 mil. In comparison the tooling to make a new unique plastic moulded body kit would be around 5 mil, the cost of designating and engineering it would be that much again. I know what my preference would be if I was a product development manager with a marketing background.
My S1 has the mounting points and nuts welded in the chassis rails for the front brace so it looks like the body of the RS4 and 260rs are exactly the same the only differences would be two pressings on the trans tunnel, for the gear leaver hole and the mounting point for the hand brake.
Edited by Burns
https://www.sau.com.au/forums/topic/148563-rs-four-s-stuff/#findComment-2794505
That makes sense.
And I still don't notice the body twisting..
https://www.sau.com.au/forums/topic/148563-rs-four-s-stuff/#findComment-2795921
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
