Hiya all,
just got a quick question regarding my R33 Series 1 Auto. I'm looking to replace the ECU (mainly so I can get it reprogrammed for 96 octane and new turbo) but am concerned that it either won't communicate properly with the current auto computer or won't work at all in conjunction.
As such, I'm wondering if anyone can recommend a good duo system, or auto computer that will work with like a Wolf, Blitz or FC ecu...or hell, even just a supplier since google can't seem to help me out with any combo of search terms I am trying.
Thanks in advance.
https://www.sau.com.au/forums/topic/148649-auto-computer/
mate just a quick reply on your ecu.. why remap it if it's already comes from japan standered tuning for above 100octane fuel.. japans premium is rated at 102octain .. so dont stuff around with it i recon .. the only thing i would sugest is running a after market ecu like i have for max tuning .. i have a microtech LT12 bigggy baked.. runs well since mine is all stock .. on 10lbs it's doing 180rwkw..and mine is a auto to.. Bill
https://www.sau.com.au/forums/topic/148649-auto-computer/#findComment-2773505
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
