  • Replies 493
Posted Images
the last two rocks... audi could use them on their advertising banners :D
btw with all the photography skills do you recon you could get rid of your currant avatar and replace it with a nice photo???. its giving me the creeps :dry:
Edited by jenkies
haha thanks, but nope.. keeping the avatar :dry:
  • 4 weeks later...
  • 1 month later...
