Hi,
I've just purhcased the following parts
Power FC
R34 N1 turbos
trust dumps and front pipe
catco cat
i've got a stardard R32 at the moment.
what kind of power can i expect from this setup (safely)
Also, will the stardard clutch hold? should i wait for it to start sliping then get a new jim berry one?
https://www.sau.com.au/forums/topic/148911-gtr-setup-advise/
Car should be great as long as you have a healthy engine.
You should probably upgrade the fuel pump and injectors just so it can all be done in one tune.
I just have power fc, 550cc injectors, front pipe back exhaust and run 1 bar boost = 225awkw and 253 rwkw.
Injectors should be fine. I'm not chasing anymore power.
change the rod bolts on your engine, they are the weak point in the bottom end, put in the injectors, and the pump as stated above, your car is old and will suffor easily from fuel starvation due to the old pump.
that's pretty random, suggesting changing something in the bottom end for someone who's only doing bolt ons. I think if he was going to do that there's a load of other things he should do while he's down there.
But randomness aside you should definitely run a new fuel pump and consider having your injectors professionally cleaned and flow tested or just drop some sard or nismo injectors in.
Standard clutch will already be shagged if it's not a new one. Probably best to budget for that straight up.
Just change the rod bolts? wtf is all i have to say to that.
Its totally uselsss unless your doing a bottom end rebuild. Why do something that requires motor out/apart just to change a few bolts?
2+2=15 on that one.
Anyhow, firstly you need a full exhaust to go with the front pipe etc.
You didnt list it, so ill assume you dont have it.
You'll need a clutch also.
Injectors will limit the power you will make with the R34N1s as they will make more power than the stockers can handle, but if you keep power to 270-300rwkw then you will be fine.
You'll also need a fuel pump
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
