Hi All,
Before you ask, I have done a search regarding rear brake specification and didn't find much beside stuff like their 2-piston, and also use a drum hand brake setup.
When comparing R32 GTS-t and R33 GTS25-t REAR brakes, are there any differences between them?
e.g.
- Size?
- Brake fluid line differences?
- Different caliper mounts?
- HICAS?
I am asking because I would like to install R32 or R33 rear brakes into my 180SX, also converting the rear to 5-stud and utilising the drum hand brake setup.
I am aware for the conversion I would require all from the skyline:
- Calipers
- Rotors
- Hubs
- Hub Uprights
- Drum brake components
- Hand brake cable
- And Possibly a HICAS lock bar if the skyline uprights have HICAS mounts
I was quote a cheaper price for the R33 rear brake setup than R32 from my local wrecker, I don't know why either, thinking that R32 parts would be cheaper..
Your help is truly appreciated, thanks!
Cheers,
Johnny
Apparently R32 and R33 rear calipers, rotors are all exactly the same!
the R33 Drum Handbrake cable is slightly longer.
Im currently doing a 5 stud conversion on my 180sx, the parts im using are:
R33 Rear calipers
R32 Rear rotors
R32 Bakcing plates and Drum handbrake setup
S14 Rear Hubs (r33 or R32 wont fit a S13)
R33 Handbrake cable (drum handbrake cable mounts are required)
hope that helps!
Edited by hawker05
like f**k they wont :)
i done the whole conversion on mine myself and i used
r33 rotors and calipers and brake lines (slight mod to stock solid line)
r33 hubs which bolted straight on..
r33 drum brake setup and r33 handbrake cables
I've heard the whole r32gts-t rear subrframe can simply be swapped. Givgin you 5 stud + brakes in 6 easy bolts :-) Assuming the skyline unit would be bigger and stronger than an s13 one, the diff could also be un upgrade ?
if your goin to swap whole subframe axles hubs and diff get one from a r32 gtr.. bigger axles and stronger.. i'll be doin it to mine in couple months or so.. if i end up blowing my diff or snapping an axle
r32 gtst runs same size axles and diff is about same strength.. not really worthwhile in my opinion
    • Yes that’s what im trying to decide. Should I do stock gtt box or enclosed or open pod.
    • Also, I note OP is in Melbourne, which begs the question... are you aware of how illegal your car will be with a turbo, and intercooler and any sort of filter change? I don't know how you can get past the "2 intake mods" "rule" that seems to exist in Vic. Fully engineered might or might not get you there.
    • If you have a turbo... then the ducting holes I used to feed the pod are not available because your intercooler likely uses them. If you have an intercooler, your IAT's are going to be goverened by how good your intercooler setup is. I'm yet to really see anyone check IAT with a snorkel/boxed pod/proper CAI versus and unshielded pod. It would be interesting! But I suspect that the differences would not be so noticeable as if you were N/A as the intercooler is where the air is being cooled.. and out in front where the FMIC would be is a pretty good spot for it.. When I was turbo I pushed the stock GTT box as far as I could and made some pretty good power out of it, and noticed on the street I never made the same power/boost. Then I did a before and after run with a pod filter versus the box and picked up about 9PSI from the same boost duty cycle and about 50KW instantly. I never ran the stock box again, and recently removed it for my N/A setup. The box is restrictive to a degree - Even with the V8 setup I noticed I picked up power by removing the box completely, so punching holes from the bottom of it to get air from the passenger guard *helps* but the most effective one in my case was simply having the ducts, a pod, and no box around it. In my experience, *more* air was better than cold air. The air (with ducts) will be cooled off as you start moving, and especially if you start moving fast (a race track). It actually moves around quite a bit as you can see.
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
