The thing I don't like about them (i'm not knocking you, because i've done the same thing in my car), is that:
firstly, the leds are directional. There are cold spots with less light.
secondly, they're dimmer than the stock bulbs.
thirdly, the blue doens't light up the needle.
I've currently got the wide angle leds in my cluster, but they have all the problems i've said. I'm gonna be making my own to solve the problem.
Yeah i think your right.
I like my stock white against the black with a red arrow effect...
Yeah that's why you have to face them downwards or to the rear like I did, the cold spots aren't preceivable with the naked eye, the camera can pick them up though.
With the triple gauge you have to aim the LED to the centre of the needle.
I bought 13000mcd LEDs, they're bright enough :yes:
How did you make the symbols on the climate control light up? did you cut out the pictures?
My 34 had those symbols just painted on.
Was a c**t at night time.
Dude, your lights were blown, they look painted but aren't :yes:
Wow, Very very schmik
I'd like to do have those on my climate control unit.
Any chance of a DIY thread?
there's a DIY thread for changing the R33 climate control to blue LED's....I don't think the R34 would be much different...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
