Hey guys I have a 96 series 2 r33 (90,000 on clock) If I don't sell it I plan on an engine upgrade around 6K limit.
Should I rebuild or go a few bolt on's?
I don't know how long these engines live for. I have only run 12psi into it, runs stock boost most days or around 9-10 some weekends.
It has 3''inch turbo back
front mount
and high flow'd fuel pump
So should I go 1.
turbo
ecu
clutch
afm
injectors
OR rebuild it? If a rebuild is on the cards what sort of rebuild?
Cheers,
Russ
https://www.sau.com.au/forums/topic/148987-6k/
turbo - 1.7k
ECU - 1k
Clutch - 1k
afm - 300
injectors - 900
So thats 5k without labour, tuning or anything else so you'll come close to 6k by the time thats done
Simply put... the motor will last if the tune is good and you service it correctly.
https://www.sau.com.au/forums/topic/148987-6k/#findComment-2779057
I would leave out the injectors for now if you have a decent fuel pump.
Apart from that the rest is spot on...thats will give u 600-900 bucks extra for labour.
Other things to look for are suspension upgrades...say the whiteline kit..just to make it more driveable and fun to hammer around corners..
https://www.sau.com.au/forums/topic/148987-6k/#findComment-2779090
To sell a '96 Skyline and to pay $6000 on top to buy an '89 Skyline really seems bit of a backward step IMHO.. although its a GTR (approx 180aw/kw stock) , you still gonna spend $5000 on exhaust, ECU, Tune .etc. to get it to the same power level as it would if he spent $6000 on his GTST...
With a highflow turbo, ECU, Tune, Injectors, EBC and Cams... RB25DET's have seen pushing 250+rw/kw
The way i look at it, how would the owner of a stockish R32/R33 GTR, RX7, Supra or STI feel if a stock looking GTST smashed him off the lights?
My 2c
Regards,
Sarkis
https://www.sau.com.au/forums/topic/148987-6k/#findComment-2779289
turbo - $800 - slide
ECU - $1K - PFC (probably 2nd hand for this price nowdays)
AFM - $350 w/ plug - anywhere
injectors - $550 - Deatchwerks
clutch - $460 - C & B
not including labour or tune - $3160
oh, and then spend some money on your brakes
Edited by Lazy-Bastard
https://www.sau.com.au/forums/topic/148987-6k/#findComment-2779311
Yes i know that Bernard however, as an everyday driver your car see's more traffic lights then it does christmas tree's (lights at the drag strip) and if he was going to build a car just for the track, then an RB26/30 settup with powerglide box and 3500 stall, stripped interior .etc. will bring him in the 9 sec bracket... however this isnt the case... as for streetable performance, and $6000 to spend... a GTST can go a long way and yet maintain drivability as well as a MUCH cheaper insurance premium than the GTR..
Cheers
https://www.sau.com.au/forums/topic/148987-6k/#findComment-2779358
The way i look at it, how would the owner of a stockish R32/R33 GTR..... feel if a stock looking GTST smashed him off the lights?
My 2c
Regards,
Sarkis
Not going to happen unless the GTR is un well.
Not hard to have a fairly stock R32 GTR running low 12's.
As for smashing the GTR off the lights... well we all know that only happens on the drag strip with slicks on.
Having owned both the GTR and R33 gtst I can say the former offers a different driving experience... a far better one.
However $6k is about 3 years of a regular GTR maintence budget, thats just to keep it running. Having a GTST makes for cheaper long term ownership. It just isn't a GTR at the end of the day but, neither is the monthly bill. Plenty of people buy GTR's and soon find out that they can't actually afford to run them. Don't let people suck you in just on how great GTR's are without looking at the real money they cost you.
I now drive an R32 GTST for the record, I like what it does for the budget.
Edited by rev210
https://www.sau.com.au/forums/topic/148987-6k/#findComment-2779631
yeh I'll use a q45afm how much?
I plan on kkr 430 turbo, ecu remap (r32 with vct chip) 550cc/740cc injectors, z32/q45 afm,and clutch. but with a rb25 with 90,000 do you think it'll live long on say 230-250rwkw
I'm also thnkin save some cash and leave the injectors and afm stock should still get 230rwkw rite?
https://www.sau.com.au/forums/topic/148987-6k/#findComment-2779765
you will be maxing the stock AFM out around those figures...not sure exactly but do ur tuner a favor and get a VG30 AFM at least. They fit properly but u need to adapter the plug from memory.
740cc innjectors would run at about 40% duty cyle with ur supporting mods...dont bother I have much more power with 550cc SARDs and they never really get over 80%.
Get a powerFC as a minimum...not sure about thats turbo but if its small and will spool hard quickly then go fo it.
Clutch..wait for ur current one to die then replace...not point replacing one if its still working IMO...unless u want to sell it, personally I just kill them and buy a new one..if your only running ~230 it will last for a while depending on how u drive it...
https://www.sau.com.au/forums/topic/148987-6k/#findComment-2779984
These injectors, are they made by Deatchwerks? is it lik saying im installing nismo injectors, instead im installing Deatchwerks injectors? has anyone used them? what are they lik? cos i lik the price.......
https://www.sau.com.au/forums/topic/148987-6k/#findComment-2780013
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
