Q? About R33 Mspec Front Bar
Ricos
 Share
hi guys
just wondering if anyone knows how tall (top to bottom) the r33 series 1 mspec front bar is? is the hieght bigger then the normal series 1 front bar
if your not sure which bar im referring to here is a pic...if you can measure your own up for me and let me no that will be great !!!!
cheers in advance
You will need the M spec side skirts, if you dont have them as this is a deeper
centre 15 inches
Front edge....top to bottom 16 inches
Side top to bottom 16.5 inches
Edited by Allkiller
yes, that front bar is bigger than 93'~94' R33 stock front bar, I think this can be said as series 1.5
Just to correct you.
That bar came out in '94, as a revised upgrade. So it is not a S1.5 bar, as it was released for the S1.
Yes its a series 1 m-spec, not a 1.5, and it looks more awesome with 400R sideskirts than mspec skirts :( (see sig)
Got a better/bigger pics, at the same angle and side-on?
that isnt a stock M spec front bar, centre is missing and the indicator/ fogs seem smaller
It is a stock bar, with the centre cut out. Indicators "may" appear smaller because the pic has been stretched.
Here is mine:
The centre has been removed, to allow more air to the fmic, and the cut holes plastic welded to look neat and stock.
 Share
