  • Replies 67
I wonder if we should put something out on Skylines Down Under, since this was the main site people started with before SAU started up. I used to lurk on SAU for quite a while before becomming a member, because most people were still on Skylines Down Under, and SAU was a bit like the SVD site is now.
hey im not sure what happened to N/A he vanished i think he moved to melbourne ?
hey hey shannon long time no hear
i think we should organise and old school get together but was great to meet some of the old ppl,s the last cruise ( love the wet hey Madaz ! )
hope everyone had a great new years :D
mike
Im still here.. John's still here..
I've been barefoot and pregnant in the kitchen most of last year.. LOL Sold my skyline ages ago, now have a 545i bmw.
John's been waiting for either
a) BOTH gtrs to be going at the SAME time.. BUT his drag car will be ready next week and he'll be drag racing in Heathcote.
b) AIR to win lotto and make a decent track that is open..
Matt R - Your car is going to be freakin quick. Is it still streetable?
Timmypimp - Don't know what happen to Brad, pretty sure he'd never sell his Torana though. Also Bugalugs lives around the corner from us, pretty sure he has sold his skyline.
Edited to add - I saw 4doorsleeper on North East Road the other day in a car park of some sort. Don't know what you were doing, looked like you were showing someone your car.:)
Edited by CheekyR32
It was probably Di's car beeing checked out by a car yard, it's going to make room for an import 4x4 with a lot less power.
If I had have seen you I would have waved - its been ages. Are you guys comming to the Schutzenfest?
Edited by 4door_Sleeper
hope everyone had a great new years :laugh:
mike
yeah surte good fun went out tonight for a drive
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
