Thanks Chris for the headsup.
Dropped the skirt off to Bruce today, he should have it back to new by Friday! He's even gonna try and pull the small dint out from under the door caused by the acco and fit the skirts back on for me.
Will post pics and give my recommendations once its back on!
Cheers!
no probs.
hes done a few bumpers for me and the end result was I couldnt see where he did them on the front.
ok skirts have been plastic welded and resprayed to brand new condition! Highly recommended if you need your OEM plastic parts repaired.
Name: Mobile Plastics & Vinyl repair (Bruce)
Address: 130 Ryans Rd, Nundah
Mobile: 0412457062
He's been doing this for 13 years! Now all I need is a new SAU sticker...anyone??? :laugh:
Mobile: 0412457062
Id ask Karen...
Ill be giving this guy a call to fix my front bumper after it met the front of the car trailer last Friday and cracked... :laugh:
Mobile: 0412457062
told ya he's good.
I'm going to see the sticker people (the ones that supply the officail ones) through the week so can nab one then if you like. I'm going to try and get one for the new van as well.
told ya he's good.
cool thx! spotted u in the van after i left bruce's shop...on sandgate rd 1:30pm..
The new batch of stickers is extremely close to the originals...the batch in the middle which were organised prior to the AGM in January 2006 were the different ones.
Karen, when you say extremely close meaning they're not exactly the same as the one i've got now?? Meaning I've got to buy 2?? :happy:
the skirts i got on mine look like factory ones i think, and i got them from carmate.com.
that sux dude, I have done the same thing came out of tight spot and forgot about the side of the car but luckily never damaged like that usually just some minor scratching....
Karen, when you say extremely close meaning they're not exactly the same as the one i've got now?? Meaning I've got to buy 2?? :)
I think you may have stickers which were from the "second" batch...if I can track one of those down, you can have it for free, otherwise if you want them to match I would suggest that you'll need 2. If you have seen Mel's 34 sedan, the stickers now look like that (which is how the original first batch looked).
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
