  • Replies 55
Posted Images
S1 stagea should have the RB25DET (not neo) therefore the R33 PowerFC should be the go.
i will make a bet it plugs straight in.
hardwiring ATESSA is not necessary. (certainly not an issue on the S2 stagea)
the issue that needs working around on the R34 powerfc's for an S2 stagea is not a feature on R33 powerfc's.
https://www.sau.com.au/forums/topic/149695-power-fc/#findComment-2791519
thanks dude
do they make a s1 and 2 power fc's
or are they the same
thanks man
so i can just buy a r33 power fc
https://www.sau.com.au/forums/topic/149695-power-fc/#findComment-2792058
terminal, what is the difference in the plugs?
They are completely different as far as i know, sort of like trying to plug a domestic Australian power plug into a UK socket. i'll take a photo of an R33 and an S1 stagea and post up over the weekend.
https://www.sau.com.au/forums/topic/149695-power-fc/#findComment-2794880
the R34 powerFC (ie RB25DET neo) is not the correct version.
i don't know for a fact that the plug would be different for the R33 powerFC on the stagea. i would have thought the same engine = same loom plug. (i do not know for certain)
there is only one minor difference on the R34 plug for the S2 stageas.
if terminal is correct it will still be possible but will need more work.
someone with FAST should be able to clear up the plug question pretty quickly.
https://www.sau.com.au/forums/topic/149695-power-fc/#findComment-2794991
can i just use a neo power fc
or not
I'm not familiar with the series 2 neo and how it relates to a powerfc, i have a series 1 stagea so i've only been looking at information on that. i have a powerfc and an R33 computer with loom in my garage waiting to go in after my manual conversion, so i have all bases covered.
https://www.sau.com.au/forums/topic/149695-power-fc/#findComment-2795000
so are u just going to change the loom over to a manual r33 loom
will that work
https://www.sau.com.au/forums/topic/149695-power-fc/#findComment-2795192
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
