lan Party-Helensvale-3rd May
Guest neoGT-25
Hey everyone... how are we all?
i was in the mood for a lan and i GUESS WHAT! i found a flyer at school today :D WOOOO HOO!
its at the Helensvale Community Centre (31-35 Discovery Drive Helensvale) and on Saterday the 3rd of May (this weekend)
it runs from 9am untill 11pm (1 day lan)
there will be tournaments all day and they include...
*QUAKE 3
*CTF
*FFA
*WARCRAFT III
*MEDAL OF HONOR AA
*NEED 4 SPEED HOT PURSUIT 2
*COUNTER-STRIKE
*BATTLEFEILD 1942
-There is also servers for NON-TOURNAMENT gaming :)
they include...
*A Freelancer Realm
*Battlefield 1942 Desert Combat
*UT2003 Deathmatch
*Counterstrike War Server #1 & #2
Theres also a shop to buy food in the complex and bbq lunch and a pizza run for tea :)
But be quick... there is only 80 spots available and they are going quick!
Pricing is decent too :)
its $15 prepaid -OR- $18 on the day
(5 tickets prepaid for $60) so if theres 5 of us interested we can get it cheaper :)
gclanparty.com :))
hope to get some feedback and interest... :)
bye :burnout:
https://www.sau.com.au/forums/topic/14970-lan-party-helensvale-3rd-may/
