  • Replies 56
Posted Images
These are sooooooooooooo coool age. Cand you do a write up for these puppies in a nutshell? Or is it a little too complex for us photoshop novices??
that's right AGE... its about time you stepped out of the VIC section and did some tutes for the graphic design section.
https://www.sau.com.au/forums/topic/149791-carz/#findComment-2794545
Ummmm, it's alot easier to do them tha it is to do a DIY on how to do them. ;)
You need some big pics of the actual pixar cars themselves, and cut and paste the best fitting eyes and mouth, then free transform/distort(ctrl T) them to fit. Then it's just a case of matching the color of the donor car with the cut and pasted parts.... thats the hard part, and black cars are the hardest, surprisingly yellow was very easy :)
I use lumination/replace color/brightness/contrast and matching color tools on photoshop. Also alot of history/eraser and eye dropper/paint brush tools as well. It a bit of work to match the color, but playing around with different tools, you'll sort it out. Best thing to do is start with a white or light colored car and play around with different tools. Ctrl Z is your friend :P
Here's some more.
https://www.sau.com.au/forums/topic/149791-carz/#findComment-2794585
    • Hanging out in Perth for a conference. Asked for a room with a view… got a view of Bustdown Festival   might stroll down and go say hi to Spotto and some of the hoonfluencers
    • It’s definitely just a problem with my car, as there’s bound to be plenty of 4-600hp cars out there running a factory tank with an upgraded pump and or hanger
    • Ah right, that would be a nightmare as I only get 150ish kms before it starts having issues/half a tank, and yeah if I don’t get into it I could run it completely dry, it’s only when it comes into boost it will start to break up, it also does it in every gear which leads me to believe it isn’t fuel slosh/surge as 4th and 5th shouldn’t have enough power to cause an issue. It’s got me stumped 🙃
    • Just to confirm, if you are driving around as if the police were right behind you, you can run the fuel tank down to pretty much empty without issue yeah?
    • Ah, slipped my mind that this is an R32. Unfortunately the fuel tank isn't designed to prevent fuel surge, the tank in the R33 has a much better design.  Your options will be to keep the tank topped up or to fit a surge tank. (also that fuel strainer looks like it's seen better days)
