Kws At The Wheels
219 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • 7 months later...
  • Replies 152
Posted Images
So a guy is sellin his S15 and uses my dyno chart as proof of the power...
http://forum.silviansw.com/viewtopic.php?t=26296
Damn funny read.... :P:wub::P
Becareful guys!! Who woulda thought this shit would happen!
what a clown haha!
i fell into the same trap though, when i bought my car i didnt know much about skylines. the dude showed me it had a dyno for 215kw! with just a zorst and fmic on 10psi :(
lol, just messing around, your new car is pretty awesome!
Just a little down on power.
Jokes Dan. I'm sure it won't stay like that for too long. :(
The blokes in the US achieve some pretty impressive results with the GT3071/76's on the Lancers, oh I mean Evo. heheh :P
Does Adelaide have any High powered Skylines rolling around the streets?
Not cars that arent registered for the streets tho.
What Kws at the wheels is it making?
What model is it?
Oh yer NO exagerating either!!!! :D
Mines a GTST Series 2
Making 204.5kw
gtst series 2 r33 304rwkw
gtr32 307awkwdyno tuned on tilbrooks dyno.
Jokes Dan. I'm sure it won't stay like that for too long. :D
The blokes in the US achieve some pretty impressive results with the GT3071/76's on the Lancers, oh I mean Evo. heheh ;)
hmmmmm hks turbo already.... crap said too much....
nice 4door what turbo is that supporting mods
standard turbo pump ecu apart from 3inch exhaust (straight no cat) intercooler pod and thats it at the moment got bigger turbo ecu etc to put on yet in the process ove slowly getting it done.
ah nice would of sworn a high flow or something for such low boost
nah chris at west torrens said it makes better power of the 1 boost level instead ove 2 i did have it set to like 10psi or so but had a massive flat spot standard ecu didnt like it so put it down to 5psi instead ove that dual stage boost thing 5 & 8psi i think only when its colder at night the car likes boost then smetimes it show a little flatspot depends on the weather too i guess standard ecu's suck
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
