  • Replies 163
is this still going or what?
Ok im in if any of these gona fit R33 GTS4 (non turbo) 1994 ? black one, deliverd to 2155.............Please let me know asap\
Cheers,
Hi guys,
Sorry I haven't been replying in this thread for a while, been flat out at work.
http://www.skylinesaustralia.com/forums/Ra...rs-t207720.html
Here's the new group buy, please register your interest over there and we can get things moving.
Cheers
BASS OUT
  • 3 weeks later...
Hey ppls.
As many of you may know, I manufacture a vast range of Aluminium Radiator Air Deflectors.
Currently I have designs for the following cars.
R33 GTS-T Series I
R33 GTS-T Series II
R33 GTR Series III
R34 GTT Series I Standard Front Bar
R34 GTT Series I Nismo Aero Front Bar (Also fits R34 GTT Series II)
Stagea Series I (with and without scoop)
Stagea Series II (with and without scoop)
I also have a design that seems to fit R33 GTR Series I or II but not yet confirm. This model was custom made for a guy with an R33 GTS-T fitted with an R33 GTR front end. Was a tight fit, but it fit.
The guides are made from 1.2mm Aluminium and will be powder-coated in a satin black finish. I have decided not to anodise them as the finish on the aluminium must be perfect for it to look as good as it should, and manufacturing processes can’t always guarantee this. You can delete the powdercoat from the guide, this will save you $5.
The price varies according to the model, and all prices must add freight. The guides are sent bubble wrapped in tough cardboard boxes. I use Aust Post standard post. I cannot be held responsible for any damage during transport, but I’ve not had a problem with this method so far.
Freight is a minimum of $25 but if your postcode is a long way out of a capital city, then the amount will be on a case by case basis. For instance, one of the packages I send in the last group buy cost me $35 in postage…. But I didn’t pass that cost on because I didn’t mention this clause.
Note’s from previous group buy.
I learnt a lot from the last group buy. One of these things is that I will never offer a product that I have not finalised the design for. The other is never attempt a group buy whilst in the process of changing jobs. Anywho, all those problems are in the past now. I appreciate the patience of the people from the last group buy who waited whilst I faffed around.
Pricing:
R33 GTS-T Series I
R33 GTS-T Series II
R33 GTR Series III
All $80
All $80
Stagea Series I $120 with scoop
Stagea Series I $90 without scoop
Stagea Series II $120 with scoop
Stagea Series II $90 without scoop
So, who’s in?
R33 GTS-T Series I
Mike_
linedup33
R33 GTS-T Series II
Woolls
t.head_wood
R33 GTR Series III
FAT34
Zensoku
Beagle (No Scoop)
Cheers and BASS OUT
R33 GTS-T Series I ........... R33 GTS-T Series II........... R34 GTT Series I............. R34 GTS-T Nismo Bar......... Stag Series I scop............... Stag Series II scoop
Guest
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
