If that's genuine I'm gonna be spewin cos I just bought brand new T1Rs for $230 in the same size. But the guy just signed up on the 30th of Dec and has no trader info yet...
For those interested, I think you should exercise some caution...
Edited by salad
yeah after sending him alot of messages, he seems pretty genuine.
He says he bought all the stock from Transport Tyres, who are the Falken distributor in NSW, as they wanted to get rid of them to make way for the RT615. He pretty much told me if i keep harrasing him he wont sell em to me...lol
Also if he was being dodgey, wouldn't you think he'd sell them at like 220-250 each, as no one would think otherwise, rather than 180 each.
so in your opinion he is genuine? I run these up the front of my GTSt and would love a replacement set for under $400!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
