I don't think that the one in Targa Tassie stacked it. Cause didn't it finish somewhere in the top 10? Anyways, should've seen the thing go!!!
Even better was a Super Touring car out there. It was a Pug 406, built back in 1997. It was lightening quick, and when changing gears it sounded like a F1 car!!! :uh-huh: The guy said he only uses the clutch twice, when starting the race, and when coming to a halt!!! Dog box. I've got some happy snaps and will post some up soon. But I'm gonna do a technical feature on it when I get my web page up.
I believe in wheels they said it cost around $170K to bring that N1 in for the testing/photoshoot.
Bearing in mind its probably been sold after the wheels thing....there is a line thats damn long of people who want one *including me* :mad:
This OBVIOUSLY proves the fact that white is the better skyline colour :uh-huh:
:shake:
Check out this thing....
Pug 406 Super Touring car. So many gizmo's inside!!! I won't go into details but the guy was bagging out how old the current V8 Supercars are in terms of technlogy. Like how recently they "discovered" in-cabin swaybar adjustments. Or the hydrolic jacks to lift up the cars. This stuff was in this car and was built back in 1997!!! :)
More like V8 Stone-age cars!!! :lol:
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
