  • Replies 43
Posted Images
and i dont wanna hear YOUR f**kING 2 CENTS, just plz somone give me a straight answer, thanx.
That's fortunate because we don't want to hear yours.
We don't street race because we're not immature tools with an insucurity complex.
Sadly you are, and won't fit in here, so perhaps you should try a nice big glass of "fu** off the forums".
It's good for what ails ya.
https://www.sau.com.au/forums/topic/150171-racing/#findComment-2798162
Isn't there a city to lake fun run??? Thats street racing isn't it???
Dear John..........we don't give a jack sh1t.......so sorry.
Actually you can race your 10 speed pushy in the Belco Mall, cos thats about all you'd own [until the cops check the serial numbers].
https://www.sau.com.au/forums/topic/150171-racing/#findComment-2798800
Dear John,
here's a straight answer,swigging from a can of VB whilst out on day release:"Ya tool! If ya need to ask,then ya not wanted,poofta!"
Now,here's a non-straight answer:'Ooh,Johnny,you hard-as-a-rock rebel! I just love street racers;they're so...what's the term?Ah,yes:so 'fast and furious'! If you're into that sort of stuff,call me on 1800-B.L.O.M.E.... "
And here's an answer from 'Somone'(as you actually asked for):
"John,I was hanging out at the track watching guys and girls race,when this nice SAU fella said you were asking for 'Somone' to give you a straight answer.So here you go,then:...I really think you need to check your keyboard apptitude,as it's "Simone'(as in a name)or 'someone'(as in anyone,really).I worry that you can't string a sentence together and could also possibly own something as serious as a road going vehicle as well.I've read all you posts in other sections plus this inquiry into illegal street racing;it seems that you should be somewhere other than SAU,maybe asking about 9 inch diffs,Holleys and arguing about Holdens versus Fords.Good thing it's SummerNats time;you'll fit right in with the minority that make the majority of trouble.
In short,be a good little boy and wake up to yourself.No one will condone such illegal stuff on a public forum viewed by all and sundry.If you have to ask,you should talk to any local idiot drying out in a gutter near Braddon.Natural selection may kick in and take you from the gene pool after then.Good luck finding a cell they'll pipe your music selection into..."Simone.
Everyone else has had a go;I just had to post a response....So,do you think we'll hear from John again?!?
https://www.sau.com.au/forums/topic/150171-racing/#findComment-2799798
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
