does anyone know how to work out were zero is on a r33 s1 vct cam gear?
im not talking about normal cam timing i mean the adjustment behind the inlet gear.
where is zero?
Cheers
Darren
Edited by dangerman4
Someone made a custom pulley about 12 months back that allowed them to adjust it from the front. I can't remember who it was now. I think the results were a bit disappointing and adjusting the exhaust side had more effect. Can't remember if it was an r33 or r34 engine though.
yea that was bass junky
but how does any one know where the true zero point of reference is?
i have heard several people say theres is in the middle, yet i have heard others say it was to one side.
so where is it supposed to be?
sure dialing in your cams can be a little fiddly and time consuming to get it right but im sure its worth it in the long run.
ive got the bass junky dongle on my rb25
not sure how to adjust it, dr drift did it for me
i think without the adapter plate u have to pull them out
bass junky will know
We dial the VVT gear on all our engines but you need the specs of the cams then degree wheel and dial gauge.I have the specs at work but they are on the net so do a search.
would you be able to do a short write up and explain how do dial them in properly.
im running poncams on a S1 rb25det head
cheers heaps
Darren
