Greetings dudes, Ive just swung over from nissansilvia.com (cause i drive a silvia).
Now im looking at putting an Rb20det gearbox into my s13, I dont expect any of you to know anything about this conversion, but what i want to know from u guys is the following:
1) What are the gear ratios of the r32 gts/gtst 5spd??
I have found the following, can someone please confirm,
1- 3.321
2- 1.902
3- 1.308
4- 1
5- 0.759
2) What is the gearbox model, the s13 box is FS5W71C, and i have been told that the r32 rwd box is also FS5W71C (the 4wd box is FS5R30A), Is this correct?
3) Now i have also been told that the s13 Ca, s13 Sr and R32 Rb boxes are identical except for the bellhousings (and the bellhousings are interchangable (this has been confirmed for the Ca and Sr boxes!)) But i have also been told that the R32 box is 20mm shorter than the other 2 thus the tailshaft needs lengthening and the shifter needs modding. Is anyone able to measure up a box for me? I need to know overall length from bellhousing to output, length from where the bellhousing bolts onto the box, to output.And if possible the distances between the holes that bolt said bellhousing to said gearbox.
4) Whats an acceptable price to pay for an Rb20det 5spd?????
Any help will be greatly appreciated (Plus asking these kind of questions in the silvia forum didnt yield too many answers so i hope u guys can help!)
Edited by Ashman
https://www.sau.com.au/forums/topic/150442-rb20-5spd-questions/
RB20DET box's seem to go for around $500. :O
20mm shorter.. I wouldn't think 20mm would cause a problem as the yoke slides in quite far. I doubt it would strip the yoke due to it being 20mm less BUT it may cause some other issue I am not aware of.
Either way.. I would probably try it if it were only 20mm, just be sure to have that tail shaft catcher in place as it wouldn't be too fun having the yoke break and the tail shaft trying to flip the car. >_<
im thinking maybe the 20mm (if there is actually 20mm difference) may actually be in the two different bellhousings, not the box itself, ie: the ca bell may be 20mm longer than the r32 bell and people are measuring overall lengths of the two boxes and coming up as 20mm difference. If this is the case there shouldnt be a prob cause im gonna put the ca bell on the rb thus removing the 20mm problem.
Quite possible..
Got pics of the silvia box? I remember seeing a few and it did look as if the bell housing of the silvia was longer, but it can be deceiving. >_<
Are you sure ratio's are the same though.
No pics unfortunately, my box is still in the car. My extensive research says:
Ca18 5spd:
1) 3.321
2) 1.902
3) 1.308
4) 1
5) 0.838
Sr20 5spd (supposedly same ratios as rb20)
1- 3.321
2- 1.902
3- 1.308
4- 1
5- 0.759
now before u all say only 5th gear is differnet why even bother swapping boxes and all that sh#t. The reason for the swap is to drop highway revs. I have completely exhausted the changing diff ratio avenue, and the only option left is the box swap. currently does 3700rpm @ 110km/h with the ca18 box. Now i know someone will say well y not use the sr box if the rb and sr have the same gearing and the sr is confirmed to bolt up. Well that is certainly an option that i am considering but i am looking at the rb side of things purely for the cost side of things (sr boxes r around $650 +).
Edited by Ashman
well. as far as im aware. they should be the same length. the ca gearbox has a differant extension housing im pretty sure.
sr/rb should be the same length.
what exacly do you want? they all have the same gears inside.
the only diferance is the sr/rb turbo boxes have twin synchros.
from those revs im asuming you have a ca diff ratio. ie 4.3.
all 5th ratios are the sam throughout the range of 71c gearboxes.
Note quite, the 5th in a ca box is 0.838, 5th in an sr/rb is 0.759. diff is currently a 4.1:1 from an sr20 silvia. I wanna drop highway revs down. And the ca seems to have a 2 piece bell and extension, whereas an rb has a 1 piece but it looks like they can be swapped.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
