Just want to know how long it took to install your FMIC kit and did it all both together properly? how much clearance did have, what did u have to do to make clearance.
It took me and 2 mates all (mechanics) 6 hours flat out from start to finish. tbe pipes on the driver side didnt match up and i had to remove the washer bottle (going to have to relocate it or modify the bottle eventually) hacked the hell out of my front bar (on and off 10 times).
I had pipes missing (cut up old pipes to fit, didnt really matter allowed me to keep my BOV) joiner missing (used a factory one) had to cut and rework the drivers side cooler pipe to fit.
Anyone else had a bad experience with one of these coolers? anyone find the instructions vague? or is it just me owning a Sedan?
Final result came good despite our improvised installation proceedure
  • Replies 46
Posted Images
what brand was it.
the GTST hybrid kit took 3-4hours both mechanics the GTiR hybrid kit took 4ish-hours was litle bit harder. and hopefully the R34 and S14a wont take more than 4 hours or i might have to charge more.
couldnt u mount it further back to clear the front are.
oh and the instructions arent acurate and just have a pic saying cut here bolt ther...
Thats why the kits are cheap mate, they dont fit for shit.
Took a mate and i 6 hours + to fit my cheap brand intercooler.
If i was going to do it again id save up for something that comes with stainless cooler pipes and uses the factory pipe positions.
Cheers
Don't know whatyour on about. IT TAKES TIME AND PATIANCE. one of my mates put his in and took 4-5 hours but things didn't line up, mainly because he rushed it and cut the hole wrong and so forth.
I have the same kit, took me most of the day but i was doing other things at the same time, one hole, didn't have to move the washed bottle, didn't come close, and it fist like a glove. I had the cooler on and off about 12 times to make sure it allined and fitted how i wanted it. I din't modify any of the pipes, and they were exactly the same as my mates.
So i think maybe you did something worng?
Did mine (a kit from CRD $400 ) in around 4hrs. It all lined up and fitted well. Nothing to be cut or modified.
It was all straight forward.
Im with you mine waws faily straight forward, the passenger side factory hoe had to be enlarged and a hole cut in the driver side but it was or a non event.
If i did it again i would but a kit that used the stock pipes in the engine bay. I dont like hte idea of the cooler pipe in between the radiator and engine where it gets very hot.
The kits from Just Jap and CRD are the same, which highlights the fact it comes down to whos fitting the kit.
Wether or not someone is a mechanic or not is completely irrelvent, in fact blind freddy could install an intercooler kit!
Cheers
Let me guess, you have tried to install your own intercooler kit before and failed miserably? Because your comment above is complete crap :cheers:
Spot on.
From my experience, it only takes one pipe to be slightly out of alignment for the whole overall fit to be thrown out.
I always do a dummy fit and pipe alignment before cutting the hole in the guard, and trim the front bar a little bit at a time to get it just right - if you take the time and patience while fitting, you will end up with a good quality result :D
like i said, mine fited nicely, no problems, no nothing, exactly how and wher it should have gone. YOU just need time and make sure everything is allinged, the hole in the right place, and so forth.
Edited by WogsRus
Sorry to be the one to point it , but it was your install that went pear shaped im afraid.
As for your BOV pipe, you dont need to touch or go anywhere near the plenum crossover pipe that the factory BOV is mounted on when installing any front mount kit
Well my problems arose from my car being Type-M and having that extra lip at the front (is it for stability or something?) It stopped everything from aligning up and the kit sticks out so far that it pushes the kit out on both sides at the front (which now needs a respray) Cutting the battery hole was a bit of a pain but meh, most annoying thing for me was on the right side of the engine, trying to align the piping into the original elbow. Other than that and quite a few badly welded fins (onec again, meh) it's good, looks fairly decent, and well i can't notice too much of a drop in performance cept for the obvious throttle lag
you need to trim the stock plastic fornt bar to accomodate for the piping and FMIC. I had to trim about 4cm of mine to fit and it looks good no problems at all.
What needed to happen was to install the top pipe and cut the hole in the guard to accomodate that position. If i did mine as per instruction it would have possiblt not allined as well as it has.
All the welds on mine look A1, my mate is a welder and was very supprised when he saw it.
I had never done this before and bought a unbranded kit off ebay.. No instructions so got the Hybrid ones which are close.
Took my time and did it bit by bit with no help.
Took a few weeks to get the courage to go full-on and finish it.
CUt the front bar and a few odd bits on days here and there.
Removed the front bar and replaced about 8 times bofore finishing.
When i finally went for it and removed the SMIC/drilled/cut/smoothed edges...ie complete fit did overnight.
Very satisfying ! :)
http://www.skylinesaustralia.com/forums/in...110032&st=0
Well I took one morning and whole afternoon to get it fitted. Fits quite well. Have to "trim" the front reo bar a bit and have to trim the front bumber as well. The pipe lined up very well and the only thing that did not fit in at the end is my blinker as I have a series 1. Fit a cheap blinker from supercheap store and problem solved.
The kits fits like a custom one... you have to trial fit it.
no workshop putting something in would just "put it in" without doing a dummy trial... so you should be doing the same.
on that point i failed to mention my aftermarket BOV was on the intercooler to plenum corssover pipe not on the plenum crossover pipe (not me, came from japan like that) and the instructions said the box should contain 4 pipes for RB20/25, etc but there were 3 and 2 silicon joiners when the instructions said 3. ill get a pic of the engine bay to shou the end result. Being a Sunday there obviously wont open.
But in saying all that the performance has improved quite a bit.
next mission - what to do about my washer bottle
Depending on where you went thru your washer bottle....
Other kits were meant to go thru there and were supplied with half size/replacement bottles. (i think from memory)
That might do the trick :kiss:
i have the same kit, took me 6 hrs to do it on my own...
my washer bottle sits right above where the pipe comes through you should be able to make that pipe sit lower and keep the factory position of the washer bottle...
i had to shave my bar to clear the cooler, i had to shave bits of the A/C thermo and had to shave the tips off my clutch fan & cut the hole under washer bottle...
did your clutch fan clear that pipe running up top near radiator???
there is a little screwing around involved but value for money is TOPS! :kiss:
LOL
I can see how someone can fail at fitting an intercooler kit, seeing as they go on a heap of different ways and all.
we mocked everything up, cut the hole where the instructions said to and we still had to cut a 3" section out of the pipe going from the cooler to the intake plenum.
And yes i had to cut the shit out of my front bar to make it fit but thats to be expected.
    • Would be easier to just run the RB25DET gearbox, all you would need to do is have the tail shaft / prop shaft shortened. S15 uses the rear ABS diff sensor for the dash speedo, so you can skip using the gearbox speed sensor.
    • Was the failed sensor by any chance this one? Did it just fail or start pissing on itself? I ordered one too, for fuel pressure monitoring, and now I am hesitant to put it in, hehe. Where did you find a brand one?
    • You'd be insane, when a brand new 8HP is ~$4k, and all the work to put a 6 in would cost the same as an 8 and the 8 is a completely established swap. If you think that getting a cheap Falcon box is going to make it a cost effective exercise, then you're not accounting for the extra $10-15k that the task will consume.
    • any further information on this? also interested in putting a zf6 in behind a rb30!
    • They're all horrible. X-Trails have had a nasty sounding 4cyl since forever, no matter what engine family it came from. The CVTs only made that worse. Then the whole Renault thing only made every Nissan that was contaminated by them even worse again. The only fun I've had in a X-Trail was having it blown sideways across a frozen Minnesota highway at 90 mph trying to make it to the airport to get out of the frozen hellhole of Hoth. Nearly died. Was great fun.
