i was having a chat to a few different mechanics in melbourne and they were thinking that motec would be the a good way to go on the stagea
so keep the factory ecu and have the motec controlling injectors, air flow etc etc.
they are a really good ecu
just seeing what u guys think about
cheers
https://www.sau.com.au/forums/topic/150651-motec-in-stagea/
i seriously thought about installing a motec ems in my stag but then i was convinced an A'pexi PFC would be a cheaper and just as capable setup, of course it would need the patent pending "secret squirrel mod"
but i am stoked with the difference mine has at a fraction of the cost of a motec.
this in turn leaves more coinage to apply further mods elsewhere.
only thing may be if yours is auto the pfc is no good to ya i don think.
https://www.sau.com.au/forums/topic/150651-motec-in-stagea/#findComment-2804264
Yeah first 2 replies by guys with manual "S" versions (I am sure Andy will be along soon to rub it in as well, haha!). I have no idea how well the Motec would work but it has a good name and reputation. All depends on the economics I guess, what are the workshops quoting to make this a success?
Cheers
Luke
https://www.sau.com.au/forums/topic/150651-motec-in-stagea/#findComment-2804292
see they way i was thinking is this the power fc will be hard to wire up due to it has quite a big plug if u know what i mean, there for, u have to find a plug that fits it and then wire on what u need
where as the motec does not, it allready normally comes with a plug and loom and u just have to cut the wires from the stock ecu and just put them together with the ireing loom of the motec, i know they can be expensive but if u are on the look out for one second u can get one cheapish
and they are a very very good ecu.
https://www.sau.com.au/forums/topic/150651-motec-in-stagea/#findComment-2804522
I just have to be another one..
:thumbsup::rant::O;):):):):)
Yeah we know you have a manual Ian, but the others 3 all have Power FC's!
Motec
As long as you use it as a piggyback with the factory ecu it should work well
That way your auto will work well still on gear changes
I used a M4 motec in my Aw11 MR2 with a black top 20 valve 4age as a stand alone ecu
I was not happy with the final result. The engine ran great, but I had other problems with A/C control and engine stalling etc. Final cost fitted was over $4K fitted & tuned. Thes costs just ran away sorting out problems.
https://www.sau.com.au/forums/topic/150651-motec-in-stagea/#findComment-2805224
Motec
i was thinking of gettin the m4 motec thats the cheapest one still really good cause im not really aming or 10sec quater miles so that one will be good enough
there is one on ebay 1400 thats not bad.
or i was thinking about the Autronic SMC these seem to be good as well
yes i will be useing it as a piggy back system
the hard thing is gettin so one who knows what they are doing to tune it.
and not rip me off for shit work.
my car has a to4 turbo and front mount witha 3 inch dum pipe and screamer pipe
next is injectors and rest of the exhasut and boost controller
hopefully running 14 pound boost should go hard
Edited by tommyb
https://www.sau.com.au/forums/topic/150651-motec-in-stagea/#findComment-2805396
https://www.sau.com.au/forums/topic/150651-motec-in-stagea/#findComment-2805413
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
