It would depend on your level of mods.. if it's capable of flowing enough to make 7psi lower in the rev range, then yes - you would feel the difference. Otherwise a restrictive exhaust would probably make it impossible to make any more boost than 5psi up to 3500rpm.
edit - reports from that thread just posted say that yeah you do in fact feel the difference. I guess a thread wouldnt have been made about it otherwise :thumbsup:
asking a stupid question: do you notice the difference if you put it up to 7psi all the time? (EBC or other ways)
Yep your fuel consumption goes up :thumbsup: Well it did for me. But in terms of performance, you do notice it right off the line. It's only for a split second or so before you get over the 3500rpm line.. but you can see it more clearly on a dyno. With mine.. on the dyno you see a distinct spike with the dual stage, and it's flatter with it disabled.
so tred: I bought the $22 (cost more than that now) boost controller to achieve 7psi. I beleive the stock solanoid constantly "bleeds" some pressure out to the wastegate, so it takes a bit longer to build it up.
Using the manual "ball and spring" controller made a HUGE difference for me. No extra fuel usage, but much more stable and constant boost. I ran 7psi with a completely stock setup, and i'm now running 8psi with just a split dump and 3" cat.
It's a "must do" thing, I beleive.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
