It can be low or high for forgies. my engine read 120 in all cyl for a rb30det with forgies.
hey guys just running a compresion test from home whats the comp sposed to be i hear 140-160????now will it be lower for forgies???
https://www.sau.com.au/forums/topic/150775-r33-compresion/#findComment-2806364
Forgies or not.. It doesn't matter. What matters is what comp ratio the given piston returns.
Cam timing, engine temp, piston/bore clearance and the gauge its self all vary the read out.
Mine with was up over 150psi in all cylinders, all exactly the same apart from cyl 3 or was it 4!? :laugh: that was only 1psi down. BUT the motor was stone cold.
I'm just about to give it another comp test *with the same guage* after 50,000km's so it shall be interesting how it comes up.
https://www.sau.com.au/forums/topic/150775-r33-compresion/#findComment-2806509
Raa told me 5 percent in their little box on the report. whatever that means. RB25Det was at 125,000kms. enlighten me...
Probably the compression results are within 5% of one another which is acceptable but, they should've still provided a reading for each cylinder in their report. Results for a stockish RB25DET in good condition are generally between 140 - 170psi(newish engine).
https://www.sau.com.au/forums/topic/150775-r33-compresion/#findComment-2807323
Its just a comp guage with 5 little lines between the big numbers. :( I crank until it stops moving.
Unsure on the brand have never taken notice. The old man bought it many years ago, he's not one to buy cheap, he always spends the little bit more to get the better one.
The guage reads out both in bar and psi.
I'm not concerned on the actual final number as it doesn't mean a lot, I'm just stoked how spot on each cylinder is. :D
The old rb20 varied by 5psi when it had supposively done 67,000km's.
https://www.sau.com.au/forums/topic/150775-r33-compresion/#findComment-2808204
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
