where are you located....keen on the exhaust how big is the barrel?
think its 6" barrel 3" in 4" out made so I could tuck it up behind bar as I like the understated look. new never used. in brissy
guesty: sold mate
GTS20X: will look for you think I have one (was running ext/oil cooler & relocator)
nugget400hp: yes, brisbane.
Stoney: you have pm
i may have already asked you but do you have the bit that goes between the t/b's and plenum (part fuel rail and injectors mount to). if so please pm me with a price and any details.
cheers
Daniel
cheers
Daniel
The complette head and intake have been sold sorry dude, think I PMd you about it
only bottom end stuff left.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
