ok
a mate bought a brand new hand controller from kudos - for his sr20det - hand controller came - plugged it in and it froze on the apexi logo.
wrong controller :/ - so sent it back and got another one from somewhere else.
finally came today (second hand unit) - plugged it in and now there is nothing - no freezing, no light up, no picture or writing. nothing. it was supposedly to suit a sr20det.
if any hand controller is plugged in i was under the impression that even if it is incorrect, it will still start up and then freeze on the apexi logo?????
hand controller number is FCCNT 9805 - 0023
BUT!!!!! - i plugged it into my ap engineering rb20det power fc - and it lights up and i can view everything and it works perfectly!!!
My mates SR power FC serial no. is PFC SR202R 9812-033 . this was also bought second hand. And my ap engineering power fc is brand new from box about 2months.
So i was under the impression that brand new units and older units were not compatible with the older handcontrollers???
so wtf??? anyone got any ideas on this situation - as to why the hand controller isnt even lighting up and freezing with this one
thanks
-Matt
https://www.sau.com.au/forums/topic/150906-power-fc-handcontroller-problem/
According to Paul's FAQ, Apexi product chart says that for an SR20, compatible FC Commanders have a serial FCC NT (1st gen) or FCC FN or FCC3 (later releases).
So it looks like your mate has the PFC that requires a FCC FN or FCC3 serial FC Commander.
let me know once you sort it out, will update the faq if something is wrong
if its not even powering up some else is bogus. if the hand controller is wrong it fails post diag and locks at the apexi logo. open the hand controller and see if its burnt or smells burnt. i suspect its dead or something else is busted.
well thats all it is worth to me, i will pull it apart and salvage the screen and anything else, assuming they arent toast. try and return it back to the supplier as DOA and get your money back, if not throw it in the bin
sorry guys the HC is fine its the pfc thats stuffed i.e water damaged
it doesnt seem to want to power up the HC although the PFC still seems to run the car fine for now
and the HC runs fibe on Huddys FC
Edited by 1400r
bit odd, maybe the pfc socket for the hand controller is toast?
where is the "water damage" idea coming from?
when u open up the PFC do you see any burnt or damaged stuff? does it smell? check the pins running to the PS2 socket for the hand controller
hey ryan post a pic up !
the water damaged seemed to off come in through the plugs for the handcontroller (from memory)
it is just odd that with another hand controller that 1400r had before it DID load up and freeze on the logo, now with this one - it does nothing (BUT works perfect on my rb20 AP PFC)
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
