Hey guys, I'm going to be importing a 350GT very soon. I was checking out a certain type of kit for it, but unfortunately I didn't write down the exact name of the company. If someone could help me out, I would appreciate it...the company name (from what I remember) was something like Antechlon. Also if you guys have any links to alternatives for me, that'd be great.
Cheers!
https://www.sau.com.au/forums/topic/150976-350gt-kits/
350GT's are a V35 spec... with the biggest engine anyways.
the workshop I do some work for is in the process of importing a buddy club kit for a V35 coupe... and I think there's plans to mould it.
https://www.sau.com.au/forums/topic/150976-350gt-kits/#findComment-2812362
funky...I actually saw this Antechlon (or whatever it is) bodykit/car on the j-spec website, but it has since been taken off. It was a silver v35, you wouldn't happen to know/be able to find the exact name of it would you?
https://www.sau.com.au/forums/topic/150976-350gt-kits/#findComment-2812588
ahhh you'd be talkin about this puppy:
http://www.j-spec.com.au/list/7578
Anceltion :happy:
http://www.anceltion.co.jp/
... and might I add the orange one on their website is horn!
https://www.sau.com.au/forums/topic/150976-350gt-kits/#findComment-2813903
Anceltion :huh:
oh SNAP! thanks buddy...that rear bar on the silver one is smokin hot.
https://www.sau.com.au/forums/topic/150976-350gt-kits/#findComment-2814184
  • 3 weeks later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
