  • Replies 94
Posted Images
Does the fact that isnt one detailed picture worry you?
because it worries me.
You cant see anything clearly.
without far more decent pics, i say stay away.
whats the setup anyway?
i made 270rwkw on pulp and 369rwkw on 104 octane with the stock item with as good response as those with front facing
you made almost 100kw's more using 104 octane fuel?
I was looking at them last night they look very cheapo, would need alot of cleaning up. Theres a guy in geelong i think selling them on ebay too, he has better pics.....
The guy in Geelong selling these on ebay even says he has done before and after dyno runs with a 14kw increase with 28nm increase in torque...
For $300 I reckon it would be a pretty good upgrade just to clean up the engine bay a bit..... get rid of the intercooler piping, clear access to spark plugs, get rid of cross over pipe and relocate rubber hoses...
Can you get cast aluminium smoothed and polished ok?
I am gettig one this afternoon. Will need to probably clean it up with a dremel but arounf the water jackets but meh.
At least I can run top feed injectors now without having to make some gay spacer up for the stock plennum. Thats my main reason for getting it. Also save on the piping.
and no I couldn't have just got side feed injectors I aleady had 700cc top feeds doing nothing thats why.
Anyway I have a pretty decent camera now so when I get myn I can put some really hi res pics up if enough people are keen to see one up really close.
Edited by James_03
Id be very interested in finding out the quality of these items, If it doesn not cause any of my cylinders leaning out then i will buy one. I know a guy wiht a online store that is starting up http://www.iconautoworkz.com.au He will be able to do us a group buy cheap!
Any one got any info on if it will cause any uneaven leaning out?
Posts to: Australia
Item location: HongKong,ShangHai, China
Bank: Bank of Melbourne
BSB: 733-178
A/c NO.: 588-444 A/C Name: Ying Wei
Sounds way to suss for me, i've heard of hepas of scams like that.
I've also heard that the intake manifolds u get of ebay liek the greedy style copies "which this one appears to be" are of poor quality and the wall thickness is minimal which can result in cracks!
Exhausts manifolds on the other hand from ebey are ok i've heard.
Those things are $70 US a peice when you buy over 50 lol I noticed some chinese import/export website and i sent them an email just to see what they said and thats the price i got.
As far as those sorts of items it's a little risky. I purchased a low mount turbo manifold from some sonofabitch (not naming any names) on ebay and the lovely welds they had on the manifold (pertruding welds) came off from the inside and went through my brand new 15minute used turbo..... lovely :happy:
Learnt my lesson the hard way.
"STAYAWAYFROMEBAY" :sorcerer:
I certainly wouldn't put one on without serious cleaning up first. Check here to see pics of my SR20 manifold
http://forum.silviansw.com/viewtopic.php?t...hlight=manifold The before pics still had about 10 hrs worth of clean up. I modded the manifold to take a bigger throttle body, which allowed better access so I cleaned it up some more.
I used a drill and a long shaft I bought at bunnings and some stones. I have had several areas on the manifold welded up, the casting is not brilliant, but for the money if your prepared to put the effort in it can save some cash.
Just wondering if the manifold required welding up, or did you get it done as a preventative measure. as far as the internal finish is concerned, it is certainly no worse than the original manifold, but a clean up certainly wont hurt.
I bought one off ebay, actually the same one as posted above. Unfortunately it arrived damaged, most probably through the poor packaging and will be sent back to the supplier. So far he has been good about the whole deal, so lets see what happens.
You get what you pay for. I was aware of the poor quality, as i have seen one on another car, at my mechanic's w/shop. I plan to linish and sand the outer surface to make it smoother b4 powder coating it. It should look pretty neat by the end of it.
Below are the pics i took, to right a report to the seller.
I'm posting it here not to ruin your gb.
Mine was packed the same and the first 3 pics demonstrates the recieved condition of the poorly packaged item. Hope you don't get any dramas :)
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
